Hi there
I’m builing a box with 14 buttons using only the the Core and DIN modules. Whenever I load any syx file it looks to load ok using MIDI-OX or the sysebox but the only data i’m recieving from the box is a sys ex message of:
F0 00 00 7E 40 12 01 F7
This repeats every 2 seconds
Any help would be greatly appreciated
Rohan
Looks like you only have mios burned on the pic.
have you downloaded (via midi connection) your application to the pic?
I loaded midibox 64 v2.3 via midi which did stop the sys ex data but the buttons were not producing any data and when I powered down and back up again the original data repeats every 2 seconds
No - the 2 second message means you don’t have mios loaded yet. You only have the bootstrap loader.
You need to send the mios_v1_7.syx file from the MIOS download first - then send the main.syx from the MidiBox64. Remember you need to ground A0-A7 of J5 on the core if you aren’t using any Pots. (or you can change the number of connected pots to 0 in the main.asm and re-assemble it.)
Justin
p.s. This really isn’t a MIOS Programming question - it should be posted under Testing/Troubleshooting.
