Hi everyone,
I cannot get my SEQ v4 to record midi from my s0xb0x…
s0xb0x on midi in 1. When I start the s0xb0x pattern (from the s0xb0x on “pattern edit” mode), it starts the SEQ… But it doesn’t record any step. Am I forgetting something?
Thanks for your help!
First check: Are you in run-write mode pattern edit or step-write? Check the Xoxbox manual here for instance.
Two: Does your xoxbox output MIDI at all? Check with other gear. The Xoxbox is hand-built so you’re not guaranteed a fully functional Xoxbox unless it’s been tested.
On the other hand, if the sequencer starts when you start your xox there’s gotta be some issue with setting up the MB-SEQ for recording…
Good luck!
J
Thanks for your fast answer!
That was something with the xoxbox… It seems it does not send midi notes when in pattern edit mode, only a midi clock, start and stop. I have to use the track mode. It’s less convenient but it works great!
