This is my first massage on this forum and iโm not even sure is this right place for that
But:
Does midi box work propperly whit propellerheads Reason 2.0 ??
But:
Hi Etko,
i do not have Reason 2.0 but I think it will work perfectly with a midibox if you configure both correctly.
If you are planning to build a midibox but are not sure yet what you need, you could try to use vmidibox64 (see serge.ucapps.de) at first to configure and test the connection between your pots and buttons, and the Reason functionality.
Vmidibox64 is a program that partially emulates the functionality of a hardware midibox by software. If you have defined the knob settings in this program you could later dump them into you hardware midibox.
You probably need the MidiYoke driver to be able to link vmidibox to Reason without a midi loop cable.
Good luck,
Serge
Yes, midibox itโs the perfect partner for Reason 2.0, you will want build a lot of midiboxes for a total control, I have some sisex archives (free for all) ready configured to work with Reason, for example you can control ALL parameters of Subtractor at realtime or Redrum or the mixer, or configure it at your way, but unafortunately the best piece of Reason, the sampler NN-XT have not midi* implementation, only works with mouse.
Up to 4 matrix sequencers can be controled whith one knob, ALL 32 paterns (buttons too can do it).
* NN-XT have a very basic midi implementation.
Thnx for usefull informations. I tried Virtual MidiBox with Reason and it work perfectly!! Where can i find SysEx for Reason??
Are on the way to Serge, soon available on the web.
you can download the sysex files for Reason by Amando here :
http://users.pandora.be/sdrsite/sites/serge/vmidibox/dev/presets/ReasonMidibox64AmandoSysex.zip
Thanks Amando !!!
Regards,
Serge
Hello,
can you help me how to program the pattern of the Matrix Sequencer with the buttons of the MB64?
Thank you,
Regards
Helder
Yes, I am haveing the same problem, but with the bank select buttons on the drum computer. Each button is about 4 cc values apart.
For example:
Button Value
1-----------1
2-----------4
3-----------8
4-----------12
All your pattern select buttons should have the same CC#, but change the [###] . Also make sure the button is set to mode 0
I am not sure how to get the bank select to work.
Anybody have any ideas?
Good Luck! ;)
-Jost
If i understand correctly, you need to assign your buttons on the same CC#.
Set them to On Only.
Set them to send value 0 the first, 4 the second, 8 the third and so on with the vmidibox.
That should do!
