Rear panel file?
Quick question:
Is this -
http://www.ucapps.de/midibox_seq/tk_mbseq_backpanel_v1_1.zip
The correct file for the current v4 pcbs from Smash?
I just want to make sure nothing has changed before i cut a test plate.
Thanks, Julian
thats for the STM core, not the current LPC one although it should be spaced the same and should fit if you didnt use the magjack. PM your email and I’ll send you my files, I just did a SEQV4 based on the LPC core and the 4xIIC modules. I also used the dummy slot in the 4xIIC module as a DINSYNC port..
thank you,
work email is -
Here they are: LPC17 layout
The way this is designed to be mounted is via 2-56 threaded screws and the midi sockets that have 3 holes in them (CUI SDS-50J. The screws tap into the connector and it looks sharp. Obviously they can be omitted if the boards will be on standoffs. I also included a hole for the dummy midi socket on the IIc board to be used for dinsync
thank you,
i have your mail - i will engage my eyes and brain on them later in the day : )
thanks again,
julian
