Here is a little tip for organ midifiers. If you are tired of wasting old hardware because the tabs are not suitable for midi use, i.e. they are not momentary, they are changover switches, then this little tip might save you a lot of trouble. These typical Tabs can be made momentary quite easily. And, as they are usually semi-transparent plastic, you can light them from underneath at the same time.
So take your tabs racks out of the organ, and you will see they all pivot on a long pin.
Pull this pin out slowly and remove each tab one at a time and set aside so as to remember the order (if neccessary). Nothing will spring out and get lost.
Turn the rack over and you will see the little spring located in a hole. About 1/2" from this you will see, among many others, another hole in line with the spring hole. Sometime they have posts fitted which have to be removed, a little patience doing this, otherwise the board will break.
Take a 1/8" drill and enlarge these ‘new’ holes.
N.B. While you are at this, you can drill holes in the frame under each Tab to take LEDs. Most of these tabs are semi-transparent, and if you use bright white LEDs they will light up the tabs and look great when finished.
Now get a small flat nosed pliers, the ones with teeth, and grip the spring by two coils as close the locating hole as possible. Lift the spring out of it’s hole and place in the new hole that you have enlarged. Repeat this all along the tabs.
Re-assemble the tabs on the pivot rod, one by one, in reverse order, and now you have momentary Tabs, that will illuminate (once you’ve done the wring etc.) when pressed. All you need to do is choose suitable contacts for each Tab. Some are break, some are make, the latter are the ones you need.
Also you will help the environment by not trashing perfectly usable hardware.
good luck
Bassman
