i’ve succeeded in buidling a Core V3. I also built the a true bypass loop controlled by ULN2803A and relay. I built it following this diagram:
It works nice when givin 5 volts (that i take from J2 on the core) to the board and connecting J5 to ULN –> to the relay…
But
i have not built yet a DOUT, and wouldn’t do it if i didn’t had the following problem:
I am trying to use the J5 DOUT C code, in this way:
Init function code:
J5_IO_Init(0x00); //al J5 pins for DOUT
ADCON1 = 0x07;
TRISA &= 0xd0;
TRISE &= 0xf8;
MPROC_NotifyReceivedEvnt function code:
if ((evnt0==176) && (evnt1==65)) //wanna react to Control Change 65, channel 1, value 0 turns off the loop, 127 turns it on
if (evnt2==0) PORTAbits.RA0 = 0;
if (evnt2==127) PORTAbits.RA0 = 1;
return;
But this code doesn’t work.. at the moment the looper works thanks to the 5V on pin 1… but that’s not programmable, isn’t it ?
Am i missing something ? (surely, but what ?)
Thanks a lot in advance
