Hi guys,
I’m happy to announce that I have finished the hardware of my 8xMBSID and today I ran the MBSID V2 software for the first time. At the moment I only use one core and two 6581 SID’s. Some issues on my side that still need to be fixed:
1. Grounding problem. Connecting the local ground to the earth pin of the wall outlet introduces loud hum. On the scope it looks like the positive part of a sine wave only and it varies heavily over the ground tracks of the PCB and the (also grounded) metal case of my rack. It seems to be an internal groundloop since it even shows up on the scope when no other cables (audio/midi) are attached. When I ‘lift’ the ground everything is fine. Since I have 230V inside my case I definitely want the case itself to be connected to ground and preferably ‘earth’. How is this possible? Should leave the ground inside the unit floating (including the output grounds) and put the case to earth potential? Or is it safe enough to connect the case to the local ground (A.C. ground).
- I need to calibrate the AOUT_LC modules and rewrite the driver for the 12/12/8 bit configuration (dual frequency control and single resonance, which is routed to both external filters).
Besides these issues I noticed some strange behaviour in the MBSID V2 Beta 6 release that I want to mention:
The filter cutoff values are not between 0 and 127 but include letters (seem to be three digit hexadecimal?). When I turn up the filter frequency, using my menu rotary encoder, the filter sometimes jumps a bit back or a bit forth. Like going up from 40 to 50 in steps of 1 and after 50 jumping back to, lets say, 45, and from there on increasing.
Under some circumstances the resonance values are not limited to their limits. When I decrease the resonance I sometimes can go ‘beyond’ 0 (back to 15) and when I decrease it jumps back to 0 after having reached 15. However, sometimes it works just fine.
Anyone else with these problems?
Kind Regards,
Rutger
