when I connect AINX4 to CORE, core starts generate random midi data on random controllers..
hi dendy,
i actually had the same problem with my 2nd MB64 [[http://www.subfrequenz.net/techlog/mbox64b.htm]](%7Boption%7D)
…at last i found out that a hidden disconnected soldering joint (one of the 9 bridges @ the AINX4) was the reason of the “random data” on midi out - so may it can help you to verify all soldered connections - bridges, pots and connectors once again…
good luck!
thanx, i check it again ![]()
