rand() Random with 8Bit Pic (c -sdcc)
MIOS32Bit Core LPC17 © >  following Code works:
if(Potentiometer <= (rand() % 255)) {
   Gate = 0;}
What the code does:
The Potentiometer is a Variable > its a Analog Input: Value from 0-255
Gate is a Variable and it Gates a NOTE-STREAM.
All Together its a Note-Random-Killer > with the Pot you set the change to be killed…
MIOS 8Bit Core 18F452 © > it DOES NOT work, I got following Error:
p --disable-warning 85 --obanksel=2  -I./src -I ./include/c -I ./include/share -DDEBUG_MODE=0  main.c -o _output/main.o
main.c:224: warning 112: function ‘rand’ implicit declaration
main.c:224: warning 84: ‘auto’ variable ‘rand’ may be used before initialization
./bin/mios-gpasm modifies _output/main.asm, result in _output/main__mios-gpasm-tmp.asm
_output/main__mios-gpasm-tmp.asm:47:Error [113] Symbol not previously defined (_rand).
_output/main__mios-gpasm-tmp.asm:694:Error [113] Symbol not previously defined (_rand).
make: *** [_output/main.o] Fehler 1
with the MIOS32 bit I dont had to declare nothing…
The Quest now:
how to program a random that has a predefinied min:0 & max:255
(I am not a C-Geek, Beginner > Detailed Answer would be great > “comparing 2 Registers in Cycles take the Result and…” > I cant perform such of that into code :wink: (leider)
(the first workaround and try of building an Analog Noise generator to feed into a AIN with an BC549 failed by smoking en up…)
THANKS
ok got it… the search had results TK: 2006
   tmp = random_seed_l * random_seed_h;
   random_seed_l = TMR0L + (unsigned char)(tmp & 0xff);
   random_seed_h = 0x69 + (unsigned char)(tmp >> 8);
it makes random numbers from 0 - 255
all variables have to defied bevore of course…
