i just started to mound my first sid module and on i have a doubt about the 10 k resistor R1
on the schematics found on the ucapps’s site, says that is not required anymore, but i have this part in my kit and on the pcb are the last holes available
so what should i do?
and if is not required anymore, should i make a bridge?
from the pin 5 of the sid, i left the 10k resistor out, but now in this way i’m not connected to
to pin number 5 of IC2
Ehmm…, the connection from IC1:Pin5 to IC2:Pin5 should still be there. The resistor just connected these pins to +5V (Pullup) and can be left out. So just connect the two pins 5 and everything should be fine
You made a GOOD point there. Even beginners or people “almost there” should understand, forum is being watched by various people.
Even if Your question isn’t answered right away, don’t start new topic because of it (and if you feel neglected and your question is not answered, just post a follow up to remind us). Once you get an answer, you can be sure that topic is being watched - and even if you have a new nearly related problem, post it there.
Just to be sure: Did you follow the instructions exactly for connecting the Sid module to the Core module? The reason I’m asking this is that I ignored reading up on the docs and ended up doing 1-1 connection the first time…
tokyomatik: Can you be a bit more specific? Just saying “WHAT’S WRONG” and “i don’t understand if everything i did was right” doesn’t give the rest of us a clue. Have you checked http://www.ucapps.de/howto_debug_midi.html?
About the interconnection test, read up on main.asm, I think that’s where the docs for this app is. I’ve not used it, but if I were you, I’d start by checking all connections, then the url above. Do you get any feedback from the core (sysex messages)?
ehm …sorry guys, but i stayed all night long testing the connection with the tester and everything looks right
i tryed to upload the mios (i’m using mios studio but i also tryed with midi ox)on the pic within 2 seconds but i still receiving back this message on the mios studio in port monitor:
F0 00 00 7E 40 00 01 F7
that to me, means that only the bootloader is in the pic
now i would also try the Serge’s SysEx Loader,
but i also have another question
i did the optimized psu board x 4
but only one sid in my configuration
on the schemaics i saw that the 5vdc goes to j2 of the core but also to j2 of the sid
i did not this connection because this jumpers are already cooncted to j10 of the core
and testing the pins i get 5v
i thought that probably i was supposed to connect the 5vdc to j2(of the sid) only in the 4xsid configuration, but maybe i’m wrong…
last question about ic1:5 and ic2:5, are these pins, supposed to receive 5v anyway??
Wait a second… As far as I can tell from the SID module schematic, IC1:PIN5 connects to IC2:PIN2. In that case, you SHOULD leave R1 out. Otherwise you have to clarify, 'cus I’m not following you…
