Question on sustain
Is there a way to Note On a step and not retrigger it when the track loops around? I’m trying to get a long drone going and the retrigger is wrecking the evolvingness of my patch. I’d like a note “on” and then left alone.
Did you try fiddling with the Glide trig layer?
No I didn’t, but will try that next. Between the SEQ and the various legato/port settings on my Ambika it all started getting a bit out of control and then as usual, the tune morphed into something completely different. :slight_smile:
Some other ideas:
  • make the track divider very long, so the retrigger occurs after a longer time
  • set the gate length to full (glide), wait for the step to play then remove the step (or mute the track?). Perhaps the note off  event will not be sent in this case.
You could also try if using an Nth1 parameter layer helps. See Beginner’s Guide, section 3.2.11. Nth1 and Nth2.
