Arnak wants to know how much is the current flowing when a DIN pin is clamped to ground cause he wants to use a transistor to act as a button and he doesn t want that transistor to burn out.. right?
I was informed that the module sent out a 5 volt signal so that when that 5v was switched to ground by for example pressing the stop tab down or by a reed switch on the pedal board then the key or stop tab was switched on.
To use that signal to detect the operation of a stop tab I am attempting to construct a touch sensitive stop tab which when it is touched the output from the touch circuit will supply a voltage into the base of a transistor which will turn it on.
This will in turn allow the 5v from the DIN board to pass to ground and so turn on that particular stop tab.
In order to select the correct transistor I need to know the current that will be passed on that 5volt line when switched to ground.
