Question about LC
hello !
i’m building a midibox LC and I have some question about the file : midibox_lc_button.pdf
What is the fonction of the following switch :
Nudge ?
MBLC_HOLD_LAYER?
All the VPot Select chn#X ? what is the difference between “select chanel” and “VPot select chanel”
Thanks a lot
Nudge allows to “kick” (or to shift) a track into a certain direction.
MBLC_HOLD_LAYER is a MIDIbox specific feature which allows you to switch to an alternative set of buttons/leds
Select Channel: Possibly a Logic specific feature? The cursor jumps to the selected track…
“VPot select”: selects a menu item, e.g. you can choose, which parameter should be modified (if menus are supported by the host application)
… can somebody explain this more specific? - I still don’t get this  :frowning:
THX & greets
Roger
Well, there are more functions supported by the logic protocol than you have buttons/inputs on your midibox. If you want these funcions anyway you have different layers, which means that you assign more than one function to a single button. Most suitable you put the functions which are less important in your personal workflow to the second layer. There might also be some Midibox-specific functions which I would also put to another layer.
The “clou” now is that you choose a button on your box and assign the MBLC_HOLD_LAYER function to this input. You can now switch through the different layers. Alternatively you can have a configuration which lets you access second-layer functions while holding this button (similar to an “alt” function).
If I am wrong with something, please correct me!
cheers,
rambinator
Sorry for digging this thread up again…
Is there a possibility to show (e.g. with status LEDs) which of the layers is active at the moment?
mischa
Yes…
With the default mapping of lc_io_tables_inc:
If you press the assigned MBLC_HOLD_LAYER button the layer assigned REC/READY LED turns on.
The number of the led indicates the number of the active layer (LAYER1 is REC/READY LED1, Layer2 Led2 and so on).
You can change this also in lc_io_tables.inc
greets
Doc
Thank you very much
(hätte ich doch auch im deutschen Forum fragen können :))
mischa
(hätte ich doch auch im deutschen Forum fragen können Smiley)
Yes 8) , aber so ist es Gehirnjogging…  ;D
Doc
