Quad IIc Midi R2 PIC Firmware
Hello
How can i find the right firmware for Pic16F88 for the Quad IIC Midi Board?
Regard
Tom71
Here you go:
http://ucapps.de/mbhp/mbhp_iic_midi_v1_0c.zip
http://ucapps.de/mbhp_iic_midi.html is the parent page with all info.
Ok. I was not sure that this is the right download for the quad board.
Has every PIC on the quad board the same hex file to burn or must be set a different ID in the firmware?
You’re welcome. Device IDs are hardwired using IO pins directly on the PCB (or selected with jumpers on oldschool I2C modules).
Thank you latigid on
Now i see the different on pin 12/13/14 in the schematic.
