I am having a problem with my psu. I made it a couple of weeks ago and the output voltages were fine (around 5 and 14). I then connected the bankstick bits to the core and now for some reason the output voltages of the psu are different (about 1v and 9v). Is there something wrong with my psu board or is the c64 psu broken?
They should all have switches. Any power switch should be good… Depends on what the switch is switching. If It’s wall power before any transformers, get a nice rugged one. It shouldn’t cost more than $5… I have a nice little one that lights up right next to me
If there’s still some voltage on the output, perhaps the transformer is half fused or something, resulting in less output. You’ll probably need a new C64 PSU. Before you plug it in, though, you should work out if your “bankstick bits” is what caused your previous one to fail. Use your multimeter to check short circuits between +5V and ground.
if it is a c64 psu, and thats what i read from your first post, you will get some power from the psu even though one fuse is blown. ([edit]: oh, wilba said that just above) On the backside of the psu there are 2 black circles. Open them and check the fuses.
I had that problem last week. check out my earlier posts.
Not strictly an answer to Chris’ problem. more of a question really:
If I wanted to have an internal PSU for my MBSid (afterall, who wants another cable brick to fall over, especially one as chunky as the C64 transformer), would it be feasible to take the C64 one out of its enclosure and stick it in the box with the Core/Sid boards, or would it be better to build an alternative from scratch? I guess you could build something a lot smaller with modern components, but I may be wrong.
And have you opened up to check for the fuses on the backside of the c64 psu, next to the power button (atleast on the cpu i have, look at the picture, i have the one on the left).
/carsten
(and to Toneburst bursting in (ho ho), i have seen a thread somewhere on the forum where a guy had 2 different psu build in to his machine. New and quite small units. i just cannot find it again)
