i’m planning to upgrade my SID control surface, waiting for SID 2.0
now i have a minimal control surface
for the new design i will use part of the the original c64 buttons as osc, waveform, filter, etc selection. the C64 contrl buttons will select the SID (1,2)
i will also reuse my existing step A control surface with LCD and menu contrl, so that i will not have to resolder a lot of things…
the leds will be placed on the top, and there will be labels on every knobs/led/button (of course…)
to use the c64 buttons, i will mount very very small PCB buttons like the ones you find in the mouse buttons (VOTI sells them).
the encorders and led will be placed by holes on the c64 case, while the matrix led and buttons will be mounted on a pcb that we be place on the top of the case
this is the GIMP image of my new design:
what do you think?
the only “problem” i see is that the buttons are “far” from the encoder and the various “section” (ENV; OSC; FILTER…) are not isolated and standalone… maybe is not very user friendly, but anyway…
If you decide to place the LEDs horizontally, I’d suggest you to put them above the encoders, not below, otherwise your hands will cover them when you operate.
