programming and compiling
Hello!
I know i’m a dinosaur but i understand almost anything about mios, programming , compiling and similars.
Ok …i have mounted a fully working midibox sid — control surf. c - 8580 sid chip.
Now i’ve mounted a aout-ng module kit for to drive a cem3379 vcf+vca , but  the problem
is to enable core for this new application.
I read that i need to modify the firmaware , i open setup_8580.asm file with wordpad.
I modify #define AOUT_INTERFACE_TYPE 3 then i save the file…(correct??) …and now?? …fog and darkness … ???
ok first question? i need to recompile the .asm and to transform it in .hex format before to re-upload it with miosstudio…right?
Question 2 : how i can do this…i already read the page of programming quickstart but is alien language for me  …please could somemone to transalte it in a simply steps procedure.
Thank you
First answer: Right.
Second answer. You’re right on target. There’s a bunch of software you need to install to make this work, and the information is all at:http://www.midibox.org/dokuwiki/doku.php?id=application_development
At minimum, you’ll want to do details 1 and 2, 3A is also a good idea.
Or just follow the quickstart.
You are right on target, doing great!
LyleHaze
