hi all.
i have built some analog guitar effects and a 3channel tube preamp by now…everything was built with a relay true bypass switching
then i have a korg a3 multieffect, using it for reverbs, delay, eq…using a fcb1010 to control my guitar rack.
what i would like 2 build, is an easy free programable midi in (from my fcb1010) to maybe 16 or more relay out contact unit.
that i could program FREE…like this.
programm change 01 from fcb1010: relay1 on / relay2 off / relay3 off / relay4 on…
programm change 02 from fcb1010: relay1 on / relay2 on / relay3 on / relay4 off…
programm change 03 from fcb1010: relay1 off / relay2 off / relay3 on / relay4 on…
i built by now for example… 1 accoustic sim stompbox clone, 2 tube screamer ts808 overdrive clones, build in a 19" 1 Hu..
every of those 3 effects has a separate input, output and relay plug…
there will be some more in the future…
and if i my fcb1010 sends the programm change XXX…my programmed effects for XXX should turn on…an my korg a3 should turn to preset XXX
if i my fcb1010 sends the programm change YYY…my programmed effects for YYY should turn on…an my korg a3 should turn to preset YYY…and so on
i have absolutly no plan of midi…
a dream would be a unit with display…where i can program it like this …change to program XXX… relayX on, relayY off…and so on
but i guess programming a switch matrix..on pc… would be much easier and cheaper…
does someone know a solution for this ???
thx …madmurdoc
