anyone knows if it’s possible to use 2 of the midiboxPlus buttons as “Program Change UP” and “Program Change DOWN”? I can assign a known program number to a button, but it would be more useful to increase/decrease the current patch number with only 2 buttons… hope some1 can help ;D
Yes, thats possible with the example Meta event which is already included in v1.909:
;; this example sends a registered value, it allows you to increment/decrement a program change:
;; first value: Fn - n stands for the selected MIDI channel
;; second value: if 00: decrement, 01: increment, 02: send without increment/decrement
;; third value: decrement/increment: don't care; else the value which should be sent and stored into the internal register
;; necessary definitions in midibox16.ini:
;; 1.1 = F0 00 7F @OnOff
;; 1.2 = F0 01 7F @OnOff
;; 1.3 = F0 02 7F @OnOff
