My SID_16F is sounding great !!! Â 8)
Thanks again Thorsten !
I just want to know how can i change patches i’ve  load with the jsynth (example_patches_v4)
by Program change ???
in the SID page :
V1.4
Patches can now be saved into a BankStick
Program Change command switches between the 128 patches of a BankStick
I’ve tryed to send " C0h XXh " with x=preset number …
P: change on the LCD but still on Alien Groove preset …
I try many many things … without result !
Help !
Gilles
T.K
May 4, 2003, 3:42am
2
Hi Gilles,
the program change event is the right one to change to another patch.
Are you sure that the BankStick has been connected properly? (You will hear a short tune when it is regognized by the MBSID). If the BankStick is not available, every patch number will point to the internal EEPROM (-> to a single patch)
Ok understand now …
There is only one patch in the internal bank …
But the jsynth “load” 128 patch in my SID without any bankstick …
If i understand well … Jsynth load but the core keep only one patch …?
Thanks !
Gilles
I just plug the bankstick …
made some new patches …
Upload with jsynth …
AND SOUNDS TERRIBLE !!!
MBHP SID is taking my nights !!! ;D
Gilles
js1
May 4, 2003, 1:04pm
5
@ gilles
You might want to read here:
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1051041533
It sound like the same problem. (and the solution is there too )
Good luck!!
(can´t wait to get my Sid going…)
js
thanks for all …
It was my fault …
I read “bank” instead of “patch” in the Sid webpage…
In fact, only one patch can be loaded in the PIC if you don’t have any bankstick …
I thought it was one bank … :-[
Everything works perfectly now with my bankstick ! ;D
Gilles
