Ma midibox envoi ce type de signal en continu, pourtant au niveau du module AIN tout est bien a la masse.
Quelqu’un sait d’où peux venir le problème ?
Merci d’avance a vous tous, j’ai fini tout mon projet, il n’y a plus que ce problème qui me tracasse un peu.
Des le problème réglé, je ferai un petit tutoriel de mon pédalier midi.
00000002299732 ms | [b2 5B 03] Channel 3: CC Effects 1 Depth value: 3
00000002299733 ms | [b2 5B 08] Channel 3: CC Effects 1 Depth value: 8
00000002299734 ms | [b5 5B 0A] Channel 6: CC Effects 1 Depth value: 10
00000002299735 ms | [b6 5B 0B] Channel 7: CC Effects 1 Depth value: 11
00000002299736 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299737 ms | [b7 5B 0C] Channel 8: CC Effects 1 Depth value: 12
00000002299738 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299739 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299742 ms | [b6 5B 00] Channel 7: CC Effects 1 Depth value: 0
00000002299750 ms | [b7 5B 01] Channel 8: CC Effects 1 Depth value: 1
00000002299752 ms | [b6 5B 0A] Channel 7: CC Effects 1 Depth value: 10
00000002299753 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299754 ms | [b7 5B 0C] Channel 8: CC Effects 1 Depth value: 12
00000002299755 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299756 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299769 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299770 ms | [b2 5B 04] Channel 3: CC Effects 1 Depth value: 4
00000002299771 ms | [b2 5B 08] Channel 3: CC Effects 1 Depth value: 8
00000002299772 ms | [b5 5B 09] Channel 6: CC Effects 1 Depth value: 9
00000002299773 ms | [b6 5B 09] Channel 7: CC Effects 1 Depth value: 9
00000002299773 ms | [b7 5B 0A] Channel 8: CC Effects 1 Depth value: 10
00000002299774 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299775 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299776 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299788 ms | [b2 5B 04] Channel 3: CC Effects 1 Depth value: 4
00000002299789 ms | [b3 5B 05] Channel 4: CC Effects 1 Depth value: 5
00000002299790 ms | [b3 5B 08] Channel 4: CC Effects 1 Depth value: 8
00000002299791 ms | [b5 5B 0A] Channel 6: CC Effects 1 Depth value: 10
00000002299792 ms | [b6 5B 0A] Channel 7: CC Effects 1 Depth value: 10
00000002299793 ms | [b7 5B 0B] Channel 8: CC Effects 1 Depth value: 11
00000002299794 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299795 ms | [b6 5B 00] Channel 7: CC Effects 1 Depth value: 0
00000002299795 ms | [b7 5B 01] Channel 8: CC Effects 1 Depth value: 1
00000002299806 ms | [b1 5B 02] Channel 2: CC Effects 1 Depth value: 2
00000002299807 ms | [b2 5B 03] Channel 3: CC Effects 1 Depth value: 3
00000002299808 ms | [b3 5B 04] Channel 4: CC Effects 1 Depth value: 4
00000002299809 ms | [b4 5B 06] Channel 5: CC Effects 1 Depth value: 6
00000002299810 ms | [b5 5B 07] Channel 6: CC Effects 1 Depth value: 7
00000002299811 ms | [b6 5B 08] Channel 7: CC Effects 1 Depth value: 8
00000002299812 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299813 ms | [b7 5B 0A] Channel 8: CC Effects 1 Depth value: 10
00000002299814 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
00000002299815 ms | [b7 5B 00] Channel 8: CC Effects 1 Depth value: 0
00000002299825 ms | [b4 5B 05] Channel 5: CC Effects 1 Depth value: 5
00000002299826 ms | [b4 5B 06] Channel 5: CC Effects 1 Depth value: 6
00000002299827 ms | [b5 5B 09] Channel 6: CC Effects 1 Depth value: 9
00000002299828 ms | [b6 5B 0A] Channel 7: CC Effects 1 Depth value: 10
00000002299829 ms | [b7 5B 0A] Channel 8: CC Effects 1 Depth value: 10
00000002299830 ms | [b6 5B 02] Channel 7: CC Effects 1 Depth value: 2
00000002299831 ms | [b6 5B 01] Channel 7: CC Effects 1 Depth value: 1
