Hi all,
back again on the ground.
I have some troubles with the USB Module. I build four of them but I get NONE to work.
Operating System Win2000.
First everything looked great. I connected the module and installed the driver. The driver is named: "Cypress EZ-USB (2131Q/2131S/2135S) - EEPROM missing "
The I started the EZ control-panel and did the download, did the “Vend Req” thing, and burned the eeprom as told in TK’s “How to..”
Still everything seemed to be fine.
I closed the Control panel. and did a restart on Win 2000
(German: “Alles gut macht der Boot…” ;D
After the restart I looked in midi-Ox for the new Audio-Device. It should be there, or not ?
I didn’t found a new device anywhere.
The USB Module is still in the device manager with the name: "Cypress EZ-USB (2131Q/2131S/2135S) - EEPROM missing "
OK. Then I tried the second USB module with the same problems.
The I tryed to do the eeprom grocess again. Now I have several problem. After doing the download, I didn’t get the system to do the “Vend Req”. When I open the “Show pending” Windows I see that it’s still pending. Nothing I can do against this.
I tryed all the programming steps again on another midiport. I reprogrammed the eeproms again and still had now new “Audio device”.
On the new USB Port I tried to programm once again. But the second time I still have the “Show Pending” - problem.
What shall I do ???
