problem with bankstick read
Hi all
I realized the core to make a control pedal for my keyboards.
At every pression of the buttons, a midi message based on the bankstick contents is generated
All is organized in patches where anyone defines a command set
Maybe the concept is a bit obscure, but this isn’t important to explain my problem’s details (if someone plays keyboards may find useful this project; if someone is interested I can explain better the working mode of the logic)
Now I finally explain the problem:
I need to read from the bankstick a 40 character string that must be visualized as patch title on the lcd display.
Here’s an extract from the file banckstick_content.inc related to strings load:
db "Europe              The Final Countdown "
db "Sonata Arctica      Full Moon           "
Here there is my problem : Countdown become Countdownn and Moon become Moonn (the other words remain correct). It seems the problem is the “o” and “n” letters followed by a space.
I’m sure that strings in the bankstick are correct.
Using the message sysex “F0 00 00 7E 40 00 03 00 F7 F0 00 00 7E 40 00 01 40 00 40 00 F7” I obtain the bankstick content and re-converting it with the syx2asm.pl I can verify that there are no double letters.
At this point the problem must be in the reading procedure
Here there’s the code which do the reading:
     movff addrhi_patchname_current, MIOS_PARAMETER2
     movff addrlow_patchname_current, MIOS_PARAMETER1
     movlw 0x80
     call MIOS_LCD_CursorSet
     movlw 0x14
     movwf TMP1
LOOPNAME1
     call MIOS_BANKSTICK_Read
     call MIOS_LCD_PrintChar
     decfsz TMP1
     rgoto LOOPNAME1
     movlw 0xc0
     movlw 0x14
     movwf TMP1
LOOPNAME2
     decfsz TMP1
     rgoto LOOPNAME2
I also tried using the function “MIOS_BANKSTICK_ReadPage” instead of “MIOS_BANKSTICK_Read” to be able to make a unique reading but I can’t get it working (I’m not expert with pics and assembly).
Do you have some suggestion?
P.S. When I wrote about the sysex message I haven’t reported the message as I use it.
If I send this message I get in reply:
F0 00 00 7E 40 00 0F 00 F7
F0 00 00 7E 40 00 02 40 00 00 00 52 65 76 F7
F0 00 00 7E 40 31 0E 0A 62 F7
And the application running on the pic hangs
Changing the antepenultimate byte from 40 to 3F I can read 74601 bytes form the bankstick (an entire 24lc512 eprom)
Hi Wonder,
it looks strange, really strange. Following test would be interesting: don’t write out the characters on LCD, but send them to the MIDI interface.
Write:
  movlw 0xf0
  call MIOS_MIDI_TxBufferPut
at the top, replace all calls to MIOS_LCD_PrintChar by MIOS_MIDI_TxBufferPut, and
Add:
  movlw 0xf7
at the end.
Start MIDI-Ox and check the SysEx messages which are sent by your core. They should contain exactly the character codes which are in your BankStick. If not, the problem could be your LCD, but just try it first.
Sending MIDI messages for debugging is a really useful - I’m doing this very often for logging and analyzing data :slight_smile:
the checksum is missing, therefore the error code
The core doesn’t hang, but it will be reset after a 02 upload request, thats the normal behaviour.
I have found out that this isn’t a banckstick problem but a lcd problem…indeed also with the lcd test function of mios studio, when i try to write ,for example, “Silent Man”, the lcd show “Silent Maan”…
