Problem setting up mios32 toolchain
Getting the following error;
P:\info\midi\midi-box\SVN_MIOS32\apps\examples\srio>make
rm -f project.hex
Creating object file for app.c
make: arm-none-eabi-gcc: Command not found
make: *** [project_build/app.o] Error 127
Using Win7 pro,
Here are my path vars;
SET PATH= %PATH%;c:\mios32_toolchain\bin;C:\MSYS\1.0\bin
set MIOS32_PATH=/P/info/midi/midi-box/SVN_MIOS32
set MIOS32_BIN_PATH=/P/info/midi/midi-box/SVN_MIOS32/bin
set MIOS32_GCC_PREFIX=arm-none-eabi
set MIOS32_FAMILY=STM32F10x
set MIOS32_PROCESSOR=STM32F103RE
set MIOS32_BOARD=MBHP_CORE_STM32
set MIOS32_LCD=clcd
I know it’s finding the SVN, if I change anything there it bombs out with a “File not found error”
Also it takes a very long time (3 minutes+) before the error pops up.
Any help would be appreciated!
Jmayes
you put yours in c:\msys\ and not c:\mingw\msys?
try ‘make -d’ to print debug info
wait, no don’t do that, it prints forever…
–debug[=FLAGS]
Print debugging information in addition to normal processing. If
the FLAGS are omitted, then the behavior is the same as if -d was
specified. FLAGS may be a for all debugging output (same as using
-d), b for basic debugging, v for more verbose basic debugging, i
for showing implicit rules, j for details on invocation of com-
mands, and m for debugging while remaking makefiles.
It’s in C:\msys\1.0\
Debug gave me 10 minutes of scrolling info ending in basically the same error
Reaping winning child 0x0a04bd08 PID 3724
Live child 0x0a04bd08 (project_build/app.o) PID 2512
Reaping losing child 0x0a04bd08 PID 2512
Removing child 0x0a04bd08 PID 2512 from chain.
It’s telling me that “arm-none-eabi-gcc” is not found (or installed)
I found this in the SVC instructions;
Quickstart STM32 Primer under DOS
We assume, that the MIOS32 repository has been downloaded to D:\mios32, and that
the Ride7 IDE (which comes with STM32 Primer) has been installed. We won't use
the IDE, but build & upload the application from the commandline instead.
So, all we need from Ride7 IDE is the gcc compiler:
C:\Programs\Raisonance\Ride\arm-gcc
and the propritary code upload tool "cortex\_pgm.exe" under:
C:\Programs\Raisonance\Ride\bin
So do I need to install this "Ride7"? If so where do I get it?
Thankx again,
Jmayes
I don’t think I’ve seen Ride7 anywhere…
http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core
The MIDIbox community have created a modified GNU Compiler Collection, ready for use with the ARM Cortex M3 platform. The toolchain contains all of the tools required to build MIOS32 applications including GCC and NEWLIB. MSYS is still currently required although may be added to a later version of the toolchain.
The Toolchain has currently been compiled for Windows (2000+), Mac OS X (Leopard or newer) and Linux x86 (built on Ubuntu 10.10).
The download directory for the toolchain is ftp://ftp.lansystems.co.uk/pub/midibox
Download the latest “windows†file and unzip into your favorite directory, If you unzip into c:\ the toolchain will create c:\mios32_toolchain and various sub-directories containing the toolchain files.
You must add the “bin†directory to your windows path, a temporary way is to type the following in a Windows Command Prompt window: (change c:\mios32_toolchain to wherever you extracted your toolchain)
If you want to make this change permanent (you probably will) follow this Microsoft KB article http://support.microsoft.com/kb/310519 This article will also help you when adding the MIOS32 specific variables later on.
I have followed the windows_mios32_toolchain_core page exactly and pm’d Gecko and he did not install anything I have not so that brings me full circle. Can someone put some light on why I am getting the “arm-none-eabi-gcc” not found error below?
rm -f project.hex
Thankx agian all,
Jmayes
When I set up the guide you referenced, I noticed that on Vista (and this should be valid for 7, too), things didn’t work out well due to the non-conforming mingw suite; I don’t know for sure if this has been fixed now.
The easy solution would be to set up a virtual machine running XP and doing the compilation there.
(If you have a valid XP licence around, of course)
Otherwise, you could help yourself by using eclipse and setting up the paths there - that should usually work,
but it’s a bit of a hassle to set it up for the first time.
I got up this morning with a fresh pair of eyes and found that I had not broken out the mios32_toolchain properly from the windows zip file which left mios32_toolchain in a sub dir instead of on the root of C. After I fixed that everything seems to work fine now. Guess it was just too late when I was working on it last night.
Thankx again all for the help!
Jmayes
