I’m working with the Midio128. Have a Midibox Core and 4 DINS working. Right now I can see through Midi-Ox that it sends note on/off signals when I ground the various data terminals on the DIN. My problem is that I cannot get an edited midio128.ini file to work. I run the perl script to get the appropriate .syx file, it seems to load fine using midi-ox, but the changes do not “take.”
For example, right now, if I ground D0, the signal is to turn on note 30 (C below middle C). I wanted to see if I could assign a different note to that pin (in this case, hex note 24) so that it would turn on the C an octave lower. I edited the .ini file to make pins 1 through 3 turn on different notes. I ran the perl script and derived a .syx file. It loaded into midi-ox fine.
I confirmed the edited changes were present when I look at the 2-digit codes displayed in the SysEx View window. I click “send sysex file†and it seemed to be sent to the midibox. The midi-ox output monitor displayed the 2-digit codes as they loaded. They corresponded to the edited changes I made to the .ini file.
So I go back to grounding pins 1, 2, and 3, and midi-ox tells me that notes 30, 31, and 32 are being sent. Sure enough, fire up my organ emulator (Miditzer), and C below middle C plays, then C#, then D. Midi-ox shows that notes 30, 31, 32 are being sent, not the ones I put in the edited .ini file.
It’s as if I uploaded a .syx file from an unedited sample midio128.ini all over again.
But, after thinking about it last night, I’m wondering if a boneheaded move on my part messed up the PIC.
Initially, I followed the procedures in the “Midio Mysteries Revealed” and the documentation at ucapps exactly, going all the way to running the perl mk_midio128_syx.pl midio128.ini script. There were no error messages and I was starting to get excited.
So I started Midi-Ox, configured everything as directed and then followed the "load the generated .syx file and transfer it to MIDIbox " step.
Except that when I clicked the send sysex button, the only file shown to send was “mk_midio128_syx.” Without even a second thought, I sent that file to the midibox. It looked like a file was transfering but no data seemed to be showing.
Immediately I realized the stupid mistake. I tried loading the midio128.syx file (it was in a subdirectory) and it loaded fine. Grounding the pins played notes, and Midi-Ox indicated that signals were being generated just fine. I figured my stupid move was harmless. Now I’m not so sure because I cannot seem to get the .syx file generated from an edited .ini file to assign pins as I want.
Do you suppose I fried my PIC so that the default configuration is permanent?
