Premade boards?
Hi, is it possible to buy premade core modules?
no you actually have to do something yourself… :wink:
you can buy kits though; you have to solder the modules yourself.
this is a non commercial DoItYourself only project>> more fun, educational, you name it …
this forum will help you with problems you will encounter while building; just try and make sure
you read all the relevant info on the ucapps.de site, the Midibox WIKI pages and the forum before; because all the info you need is probably allready there!!
good luck
thanks for the reply. I don’t mind doing the work, its just that I don’t know a great deal about electronics & thought that a premade one would be a good way to (physically) see whats going on before embarking on making my own.
I just want to start off with a few pots & buttons & work up to bigger projects.
Get into it Meef.
IT IS GOOD.
many ideas become reality.
build a core! get an lcd (even if later u remove it) . find or design a box/panel layout. you may get your panel cut for $ or do it yourself.
it may be possible you could use just 1 DINX4 (and still get five buttons via one on the core)/ 1DOUTX4 / 1CORE.buying the pcb’s will save you time and trouble.
put it all together.
by then you will have enough ideas for many midibox/mios creations for years of building. THORSTEN deserves thanks for that ! versatile platform for midi enthusiasts!
PS. sliders give u the issue of having to cut slots( can be done with any method that works..) whereas round buttons and encoders or pots are just a simple hole.
S
