I’d like to power my MBSid with a single PSU and since I don’t own the original C64 PSU, I’m wondering how to get things done.
It says on ucapps that I can use a 15V 500ma transformer for both the SID- and CORE module. But how do I hook it up? The transformer into the SID? And then? I’m really a newbie, here. So, please be gentle!
I think the easiest way to do it is to get a C64PSU anyway.. ;D there not so hard to find i guess (try ebay, flea markets etc.)
if this is no option:
If you don’t want to use the C64 PSU, you can power both modules with the same transformer or wallwart for both modules. 14-15V AC (!!!before!!! the regulation unit) are required for a good and noiseless sound.
so get a wallwart with 14V or 15V AC, power both of the modules with it but make sure you include all rectifiers/regulators on both the modules (core bridgerectifier; X1(B40C800) regulator; IC2 7805 (makes a clean 5V)) (SID rectifier+regulator for 12V)
ps the 12V is for when you use the SID6501; when you use a SID8580 you can change 12V for 9V (the regulators)
when i’m writing this i get more and more doubts, could someone verify or correct this??
