hi there
the powered usb hub from reichtelt is not available anymore.
can anyone reccomend another suitable powered hub available at reichelt ?
would this one be okay to power a seqv4?
hi there
Hey
the alternative you linked has 2A. In the Seq Manual it states 400-1000mA.
So the hub should be ok to power two Seqs without any problems. ![]()
In my opinion the switch isn’t needed. But that depends on how someone prefers his setup…
Greetz
If you are looking for “switchability”, there is also a quite cheap alternative to powered usb hubs with switches - just use usb cables with integrated power switches ![]()
https://www.adafruit.com/products/1620
(These are also available with a mini/micro usb socket)
Then you can power from any (chinese) USB wall wart adapter (rated at 5V/1A) you may have lying around…
Not that this is the recommended way to obtain clean 5V, but it is cheap! ![]()
Many greets,
Peter
You could consider https://www.sossolutions.nl/hub-met-schakelaars If you want to source it in Holland.
thanks for the replies guys !
