Hi all,
this is my first post here.
My name is Patrizio and I have almost terminated the build of my midibox stepseq with full Button/LED matrix option (soon I will post some picture of it).
I am driving with a wall power supply 9V AC, 1A all the circuits consisting of 1 core, 3 + 1/4 DIN, 3 DOUT, 1 bankstick, 2 LCD 2x40 (but at the time only 1 connected), 64 duoled.
Tonight I have finished the cabling of the system and I attempted a first run to test the enitre duoled matrix to be ok without shortcircuits. Before I tested only half matrix (32 leds) each time during the build
I lighted up all the 64 duoleds in the matrix, I played a little with buttons and after 2-3 minutes working well with all led lighted…then the blackout!
I’ve checked the power supply outs: dead!
I took another wall PSU (this time 12V AC, 1A) to verify if anything worse happened to my system and all ok, and the midiseq ran smoothly.
I played again a little, I played a cycle with all led lighted on and…again the same purpose, the seq went off.
Again I’ve measured with my tester the PSU out..nothing, blown this also. ???
Result: I never did an approximate calculation for total consumption of my system and before tonight for me 1A current for power consumption was enough but now I’m going to revise this idea.
I think to drive all the circuits in the pessimistic case of 64 led lighted on, more than 1A is required.
Have someone had the same problem as me?
Should I build an external power supply with at least 1.5A (or more) or better to leave a 1A PSU for the circuits and add a 2nd PSU only for leds and LCD?
Thank you for your help & tips.
Greetings from Italy,
Polpat
