When switching on my MIDI-Box, the power supply starts buzzing (around 1kHz), and with every LED turned on or off the buzzing changes. Is it possible, that this is because of an defect in the voltage converter?
are you using a switched power supply, or a common transformer?
Best Regards, Thorstem.
