Power For 2 Cores
Hi Again,
I wanted to purchase a Power Supply Today.
Will a 9V 500ma wall plug be ok to power these?
Midibox64
1 Character LCD
2 Cores
1 AIN
3 DIN
25 Pots
about 90  Buttons
I was going to buy from either DigiKey or Mouser.
Thanks,
Jason
Depends on the LCD you use. Backlight can consume a lot.
To be on the safe side look for a 800-1000mA supply.
Here is a link for one.  Would this be ok?
http://www.mouser.com/index.cfm?&handler=data.listcategory&D=412-106084&terms=412-106084&Ntt=*412106084*&N=0&crc=true
oh and yes it is a backlit display.  :slight_smile:
Thanks!
Jason
No, this is only a 6V supply, you’ll need 9V.
412-109063 (9V/600mA) will do it if your backlight doesn’t consume too much (take a look at the datasheet).
412-109104 (9V/1A) will do it for shure.
Raphel,  Thanks for your quick reply!  :smiley:
I am going to order the 412-109104 right now.
I’m going to look for a  male connector also,  that can be mounted to my box.
Do you know if a certain type of wire is required to connect to the core?
Thanks for all your help!
Jason
Every wire will do.
Errrr, I don´t know, but 500 mA are really ok for one LCD with backlight I think…  :-[
I mean, the max backlight´s are using is normally 300 mA (really veryveryvery bright) - normally you land between 100 and 200 mA for a “normal” lighting. The rest of your stuff (Cores, DIN, AIN etc) won´t use more than about 50 to 100 mA (max!), so 9 Volt, 500 mA power supply is ok, I think (I used more than one 500 mA supply here for the MB stuff I built - worked out well up to now).
If you won´t use LEDs (which consume a bit more) you should be just fine with your power supply.
*Please correct me if I´m wrong*  ???
Here is the Datasheets  for the Adapter and the LCD I’ve already purchased.
Adapter : http://www.mouser.com/catalog/specsheets/164155.pdf
LCD : http://www.crystalfontz.com/products/2002a-color/CFAH2002ATMCJP.pdf
Hope I can still use this adapter  ???
I might add leds ,  I’m not sure yet.
Thanks all,
Jason
Hi!
…this should be ok… it´s 9VDC@1000mA ;D
and it´s also ok to add LED´s!
greets,
pwx
Thanks!  ;D
I built the first core already,  But before i build the 2nd core is there any modifications that will have to be done,
or will i have to leave out parts on the 2nd core?  I remember reading another thread where someone had to desolder some
parts (Regulator? maybe - not sure) but that was a SID or a FM midibox setup not a MB64.
Thanks guys
Jason.
Oh… and  , Im using SmashTV’s PCB Kit.
No modifications needed. Just connect both cores J1 to the power supply.
(The modifications you mentioned are necessary for a Multi-SID with optimized C64 supply.)
Raphael
Thanks Raphael.
I know I have a lot of questions but I’m very new to electronics  ;D Please bare with me.
Thanks again everybody, for helping!
Jason
