I just got and build my first boards,Din,Core,sid, and plan to build contol a set up with 20 x 2 lcd
I got all the parts including lcd from smash (awsome) I do not have the original commodore psu
I do have lots of different wall adaptors,Which I plant to put in case.
Do I need 2 seperate power supplys?
cautious to go any futher…
I was told I only needed one 12v power supply?
limited to net use,Have done alot of reading maybe I’m missing something..
If someone could tell me what to get I sure I have or can find it or them..
I would like only one psu that I could put in case as I’ve mounted a computer type power cord to 12 700ma psu (inside) and then to power button to two pin…?
I’m looking for a link for the wire up of 20 x 2 lcd…
Thanks for your time and help
Apply power to the module after all parts except the PIC and the optocoupler are mounted. Check the voltage levels between the most important pins with a multimeter (analog or digital doesn’t matter) before plugging the PIC and the 6N138 into the socket:
IC1:MCLR(1) - IC1:Vss(12) = 5V
IC1:Vdd(11) - IC1:Vss(12) = 5V
IC1:Vdd(32) - IC1:Vss(31) = 5V
IC2(8) - IC2:(5) = 5V
I don’t understand where mclr(1) is? where so I test?
mclr is pin 1. look at the schematic and everything will be clear (ie those are the “names” of the pins)
I can’t find schematic…Is it on core page? sorry there are alot of links,I must be overlooking it?
I figured they were the pins..But unsure where because of how decribed..
Thanks for your help
Thanks
Thanks!
Trying to get power going,core 9v 500ma (good?)
sid 12v dc 150ma? good?
will these do the trick?
