1: Certainly. Also I really would consider using the standard pots, because: Theyre hard to destroy and just because of the space: If you built the pots to near to each other, you cant just turn one really fast, because, youll touch the others.
2: There is a reeeaaaally broad bandwidth: From 1.50 (or even less at ebay) up to 20 Euros or more (like ALPS high quality faders).
In greece you can find basically 2 ypes of faders. Plastic ones for about 1.3euro and metallic ones for about 3 euros.
The metallic ones are sliding so smooth you’ll want to use them all day. I have used plastic ones for my MBHP but haven’t tested them yet since there is a lot of wiring left to do…
Check “contribution in greece” forum to see where you can buy them!
Sthn athina exei o FANOS panw apo thn plateia kanigos.
