okay i got it - i soldered the ain module wrong by putting the bypass caps between the output of every chip and the connector to the core module…
if i could suggest maybe a few small improvements to the ucapps site? those pictures how to solder the ain module could be clickable and bigger - my mistake was caused by them and maybe a few else people might get confused by them? i could even make those bigger pics with my digital cam.
oh and there is a mistak on the ain site - there is written that you should solder the bypass cap between VSS and ground but in the pdf it’s VDD and ground - that was my second failure…
… VSS is ground. Would make no sense to connect it from ground to ground ;D
