i sorted it all out, my pots were log. :-\
now, dont EVER use log! only in special situations!
reason:
let’s say a pot has a turning radius of 270 deg. in that turn resistance varies from 0 to 10K ohm. translated to midi signals, the digital range can be fom 0 to 127.
now using a linear pot means that if i turn it by half of full turn radius (135 deg), the resistance will be about 5K ohm, and the midi value about 63. this means that the relation between the degrees turned and the resistance changed is linear, e.g. if turned by quarter (25% of full rotation, clockwise or counterclochwise from any position), the resistance changes by quarter (25%, + or -), and so the approx midi value (e.g. from 63 to 100). this pot will give most accurate representation of the “virtual” knob in an audio software - there will be no difference in ther positions trough all of the turning range.
the log pot simulates logarythmic function in relation turn amount and resistance. the result will be that youll turn the pot by half, and the virtual pot will move just by few deg. and when turned further, the virtual knob will start to rotate faster than the “real” pot and theyll meet at 100%
_________LINEAR________ ___________LOG_________
rotation : 25% : 50% : 75% : 100% : 25% : 50% : 75% : 100%
resistance : 2,5K : 5K : 7,5K : 10K : 0,8K : 7,9K : 9K : 10K
midi : 32 : 63 : 100 : 127 : 10 : 30 : 115 : 127
this means that the log one is more sensitive in the one turn area, and less sensitive in the other. the only thing i can think of using log pots is in example if you need to controll (lets say) volume, but in a such way that you need very fine adjustments allmost at the maximum of it, but allso be able to turn it down completley - in that situation the half knob turn area uses as fine adjustment, and the other for coarse adjustments. afcourse if you connect the power to the pot otherwise, fine adjustments will be at the 0 - 30% of the volume. oh yes, there are not 2 strict “fine” and “coarse” parts of turn area, but they blend at some point in the turning area.
i hope everyone can get a hint how a log pot works now ;D
also, is someone needs, the pots can be custom made to represent any function/relations you desire, but those cost bout 2000 EUR
