I don’t know the ins and outs of the app, but I’d be pretty sure that the SID and FM have enough work to do each main loop that they only would write to the LCD when there’s something to say.
That’s exactly right… in fact I think (nearly?) all the midibox apps work like that. I agree, it’s extremely unlikely to actually collide, but you know electronics… always screwing up when you least expect it
Also, we don’t just write one byte at a time… if we’re updating the LCD it’s going to be a byte (one of these cycles of error checking included) for every character… our LCD driver is quickly becoming slowed down by all these checks…
We could maybe reduce the slowdown by, instead of handling the arbitration with every write cycle, we could swap access between each core periodically, say, at the beginning of the LCD update functions… but of course that is going to mean we can’t make use of the LCD enable lines, so you’ll need at least (one or) two spare pins.
That said, the FM synth also uses the LCD bus for communication with the OPL3 chip, so I think we may be…
boned. :-\
Yer maybe … (It’s fun discussing it though
“text adventure…”)
But.. maybe not … As above, in order to speed this up, we can separate the arbitration process from the actual LCD write, using two other pins. This would have the added benefit of enabling the apps to share control, not only of the LCD enable lines, but of well, any peripheral they are attached to, FM included
But, even as a theoretical discussion, this is fairly extreme. Essentially, we’re talking about Asymmetric Multi-Processing, and although it’s possible, I can hear a wise little voice from my memory saying “why not use a 32bit micro instead, if you want to do that?” ;D
Regardless, I am curious about this (I’m johnny 5: “inpuuuut!”), so I’ve done a bit of research into defeating buss contention, and I think I can safely say that there’s no universally accepted “right” way to go about it. In fact, I have collected up links to about a dozen patents to different methods, and a handful of different designs as well, and that’s just the stuff that’s freely available. I had a lot of trouble sifting through the noise (we don’t really want to know too much about PCI buss contention in dualcore pentiums, or timing-based buss contention with a single processor) so I’m sure there would be hundreds of ways to do it that have been published… I’ve seen everything from dedicated MCU’s to elaborate logic to CPLDs to using a single pin with automatic latching circuitry… I ran the question by a friend who used to do military encryption hardware and he went the logic route, we had a rather interesting whiteboard session
So anyway, I don’t know if we’re actually going anywhere here, but it’s an interesting learning experience!
