Would it be possible to utilize the MIOS platform to create a MIDI router?
8*8, ins & outs, like MIDEX8 or MoTU Midi Express lines. I think this may have been proposed before, but I could not find any info on it. I bring this up because of the low latency achieved by these projects. Anyone else interested in this?
Most PIC controllers contain only one UART which can be used as a MIDI interface. Alternative DIY friendly chips are hard to find and require different programming (=burner) and development tools.
A solution could be a board with 8 smaller PIC derivatives (i.E the 16F627), which are attached to a parallel bus for an uncomplicated and fast exchange of MIDI messages. However, if somebody builds me such a board (based on my schematic) I would be able to realize the appr. firmware very quickly. But so long as I have to build the board by myself, it could take much longer (due to higher priority tasks ;-))
now whos the electronic genius who is going to help out? i would but you may end up with a really nice midibox toaster =-D (not very good with electronics).
It’s a simple master-slave design. Every slave acts as a IO device and provides a Tx buffer of 64 bytes and Rx buffer of 128 bytes. The slave firmware will be so simple, that it never has to be updated again, therefore a programming socket is not required. The brain of the system is a PIC18F based core which accesses the PIC slaves over a parallel bus. A handshake protocol (Request/Acknowledge scheme) ensures that only one PIC drives the bus at one time. Up to 8 slaves can be connected. The 100k terminators at the end of the bus ensure proper signals for fast accesses (like SCSI). The master core will cyclicaly request every slave for new data. Incoming data streams can be filtered, merged, converted and routed to any MIDI Out(s)
What about making a master with the comming PIC with USB interface, and “upti” (danish expression) we have a USB MIDI inteface with 8 in, 8 out and all sort off filter, merge, translate …
the layout look really great! But I would propose to mount 4 or 8 slave PICs on one board in order to reduce a lot of wiring effort. The junction to the core module should be 1:1 (same pinning like J5/J6/J7) to simplify the soldering. Also the pinning of the MIDI junctions should be the same like CORE:J12 and CORE:J13 so that connectors can be exchanged for testing if necessary.
