Portamento BUG!
Hi!
I noticed a portamento bug in the midibox sid a long time ago, but I been busy finishing my frontpanel so I haven’t mentioned this before now.
Set the portamento to “14” (It only happens at this value).
Play some notes around F-5, like from G-5 to C-5 while holding down the G key.
The bug makes some kind of glissando and restarts the envelopes when pitching past the F-5 note.
I have tried 1.7, 1.7a and 1.7_303beta9 and its present in all versions.
PS. To TK - I had problems with the Delay function in the osc envolope untill the new bended engine. What did you do to fix it?
Best regards
Niijaooh
:stuck_out_tongue:
http://www.midibox.org/forum/index.php?topic=5404.0
Greets :slight_smile:
ok… but still… can somebody else confirm this bug? I was wrong about it only happening at a value of 14. If you play like c5 to c6 it also happens at values close to 14.
