Hab da doch noch was gefunden
Schaut euch doch mal folgende Datei an.
Users/Accountname/Library/Audio/MIDI Configuations/Standard.mcfg
Da gibts die entsprechenden Eintrage für jedes Device!
Probiert das doch mal aus.
<key>SerialNumber</key>
<string>35FFFFFF5836393654302443</string>
<key>USBLocationID</key>
<integer>605241600</integer>
<key>USBVendorProduct</key>
<integer>381682687</integer>
<key>apple.midi.audiomidisetup.widget.xPosition</key>
<integer>364</integer>
<key>apple.midi.audiomidisetup.widget.yPosition</key>
<integer>20</integer>
<key>driver</key>
<string>com.apple.AppleMIDIUSBDriver</string>
<key>entities</key>
<array>
<dict>
<key>destinations</key>
<array>
<dict>
<key>uniqueID</key>
<integer>-672478513</integer>
</dict>
</array>
<key>embedded</key>
<integer>0</integer>
<key>maxSysExSpeed</key>
<integer>3125</integer>
<key>name</key>
<string>Anschluss 1</string>
<key>sources</key>
<array>
<dict>
<key>uniqueID</key>
<integer>1660845406</integer>
</dict>
</array>
<key>uniqueID</key>
<integer>1984258463</integer>
</dict>
<dict>
<array>
<dict>
<key>uniqueID</key>
<integer>-996743089</integer>
</dict>
</array>
<key>embedded</key>
<key>name</key>
<string>Anschluss 2</string>
<key>sources</key>
<array>
<dict>
<key>uniqueID</key>
<integer>-1660716550</integer>
</dict>
</array>
<key>uniqueID</key>
<integer>1098630591</integer>
</dict>
<dict>
<array>
<dict>
<key>uniqueID</key>
<integer>1818815627</integer>
</dict>
</array>
<key>embedded</key>
<key>name</key>
<string>Anschluss 3</string>
<key>sources</key>
<array>
<dict>
<key>uniqueID</key>
<integer>-1046718774</integer>
</dict>
</array>
<key>uniqueID</key>
<integer>1519057751</integer>
</dict>
<dict>
<array>
<dict>
<key>uniqueID</key>
<integer>-1872937943</integer>
</dict>
</array>
<key>embedded</key>
<key>name</key>
<string>Anschluss 4</string>
<key>sources</key>
<array>
<dict>
<key>uniqueID</key>
<integer>-61220049</integer>
</dict>
</array>
<key>uniqueID</key>
<integer>2047714105</integer>
</dict>
</array>
<key>image</key>
<string>/Library/Audio/MIDI Devices/Generic/Images/USBInterface.tiff</string>
<key>manufacturer</key>
<string>midibox.org</string>
<key>model</key>
<string>MIDIbox SEQ V4</string>
<key>name</key>
<key>offline</key>
<integer>1</integer>
<key>uniqueID</key>
<integer>1233726192</integer>
