Please help !!! Encoders not working!!!
No, this isn’t normal, since MIOS scans the encoders each mS, which means, it can determine up to 500 pulses (in theory). In practice I never reached such a high pulse rate…
This effect can happen when you’ve connected the pins of the encoders in the wrong order. Just try the other 2 possible combinations to find out if one of them works better
By the way, thanks for mentioning this rate. I had been curious about it, but I never bothered to actually check into how often it scans the encoders.
-Steve
Thank you all, everything works fine, I’m playing on it with a great pleasure. I shall make some fotos now to place it in midibox gallery I hope
Finally it’s ready, tested, bugfixed & working !!! My midibox 64e p4 + hardware fx’s built in Creative sb live 5.1  Yeah, I’ve made hardware “kills” by switches, disconnecting from the pot and connecting to the grond works fine!!!
http://blui.boom.ru/DSCN3818.JPG
http://blui.boom.ru/DSCN3819.JPG
http://blui.boom.ru/DSCN3820.JPG
http://blui.boom.ru/DSCN3821.JPG
http://blui.boom.ru/DSCN3822.JPG  Oh, i’ve forgot to disconnect the lcd =)))
http://blui.boom.ru/DSCN3823.JPG
Nice! :slight_smile: I’m rather surprised noone has built a PC and midibox into a single case before, it could be great for a software DJ.
A few thoughts - You might want to consider shielding the PC away to avoid EMF messing with your AINs… and careful about those fans at the front, I’m not sure if I’d be more worried about blocking them off and overheating the PC… or standing too close and having them chop my family jewels off!  :o
I don’t think this is a good idea, because then you have to upgrade / replace the package. Just do it externally and you can then use the control surface with any PC, upgrade the PC easily, etc.
-Steve
This is another one controller
http://blui.boom.ru/11.JPG
http://blui.boom.ru/22.JPG
http://blui.boom.ru/33.JPG
http://blui.boom.ru/44.JPG
