I was wondering if there is a way to play SID tunes over midi on the MB6582. I would love to hear those tunes again. Before the stereo sid the old SID project was able to do this with a buggy program, but it worked. I was just wondering if the same is possible with the stereo SID?
If i can remember correct, you needed to install application called sid-play (or something like that) then i could connect with asid-xp player on the pc. But that was for sid V1. I don’t know if that’s possible on SID V2.
Too bad that asid xp is still very buggy. But also there is nothing out that does the same like asid xp.
Not quite true. If you poke around the forum a bit you’ll find a thread called “Another way to play .sid tunes” (or sth similar). IIRC there’s some info on another tool/way of playing sid files
