Hi everyone,
After soldering the CORE, I did the voltage measuring and got some pin mismatches…
The pins on the optocoupler socket(5&8) give 5,03 V = OK
Pins 1&12-11&12-32&11 on the PIC socket give 0V = not OK
Pins 1&10-10&11 on the PIC socket give 5,03V = ???
What could have gone wrong with the soldering ? Any troubleshooting surely appreciated.
Greetz,
Kayzer
T.K
September 20, 2002, 10:56am
2
Hi Kayzer,
did you plug the 5 jumpers into the programming port J3? Otherwise the power pins of the PIC are not supplied.
Hi Thorsten,
The 5 jumpers are perfectly plugged in. It must be some soldering flaw I think…
OK I checked all the soldering and it does look good…
Could anyone point me in the right direction for solving this ???
T.K
September 24, 2002, 2:46am
5
The error must be between the programming port J3 and the PIC power lines. You could follow the tracks based on the schematic, this will be easier: http://www.ucapps.de/mbhp/mbhp_core.pdf
Well, I resoldered the J3 port and everything measures fine now !
;D ;D ;D
Thorsten, thank you for pointing me in the right direction.
Greetz,
Kayzer
