INFO: It turned out that the new chip revision still contains the EUSART bug, therefore this article is obsolete.
The original article was:
So, PIC18F4620: according to a recently published errata sheet (http://ww1.microchip.com/downloads/en/DeviceDoc/80282a.pdf), Microchip has finally released a new B4 silicon, where the EUSART bug is fixed. These are really good news for all future MIDIbox projects, because this means that in some months PICs will be available where the MBHP_IIC_MIDI module won’t be required as a workaround solution for a reliable MIDI Out port anymore!
My proposal is not to buy PIC18F4620 devices yet until some of us have verified that the right revision is available in the appr. shops. In general I think it makes sense to wait until november to ensure, that older revisions are out of stock, thereafter we could try the new one (the revision number can be checked with a program). Maybe companies like Mouser or Farnell could also be asked via email or phone before…
For those who cannot wait, they can also use in future the combination of CORE and IIC_MIDI module - it works perfectly, but increases the complexity (-> lower success rate for electronic newbies)
A new revision of PIC18F4550 (USB device) has not been announced yet.
It seems that after all, they had heard your comlaints, but just decided not to say anything : I wonder if they will have introduced another new bug for you to work around? heheheheh
I’ve developed an algorithm which can reproduce the bug on a deterministic way (see also this article: http://forum.microchip.com/tm.aspx?m=85120), but it requires a second core (with another program which is not described in this article), and a scope to catch the triggers.
However, there is an easier, but not so deterministic way: enable the MIDI merger, and send & receive a large SysEx dump with MIDI-Ox. When you compare the dump (function provided by MIDI-Ox) you will sometimes (!) see additional zero bytes
I wonder if you order a sample from MicroChip, if they will give you a older version just to get rid of there defective PIC inventory.. just a thought.. So beware for the newbies..
I ordered the 18F4620 I/P about 2 1/2 weeks ago from MicroChip and I received a PIC with a Packaging Information number " 0605 4R3". Pay attention on the bolded numbers.
I also have got a couple with the same numbers 06054R1, did you figure out if they were the ones with the bug?
Could these chips be loaded with the bootstrap loader from the JDM programmer? If so does anyone have a guide on how to load it up ang get going with the new pics or is it the same as with the old ones?
Also if all of that works whats the chances of TK allowing people with suitable new chips access to the applications to try out? Im keen to try the new SID and sequencer apps. I will keep the old pics on hand to swap if the new apps are still buggy.
i don’t know about the JDM, but my 4620s burned ok through my PIC Burner.
It’s basically the same procedure like with the old ones. You only need to select the right binaries in the mios_v1_9_update package. The applications are binary compatible and don’t need to be recompiled
Just only take care that you are using the latest MIOS Studio release, which contains a bugfix for PIC18F4620 uploads
I haven’t started with MBSID V2 yet, but MBSEQ V3 is nearly finished. It’s available via email request.
This program displays the Revision ID of a PIC18F and sends it
also via MIDI as CC# event
Known numbers (mostly documented in the errata sheets of the PIC devices)
- 0427: PIC18F452 C1 Silicon (latest and greatest)
- 0C03: PIC18F4620 A3 Silicon (contains EUSART bug)
- 0C04: PIC18F4620 A4 Silicon (contains EUSART bug)
- 0C06: PIC18F4620 B4 Silicon (the good one w/o EUSART bug)
[/code]
