hi!
I found a new PIC18f programmer :
http://members.naspa.net/djs/software/pic18f.html
which is a plug on the parallel port… And the woftware works under linux.
I think I can use it without any care?
thanks!
hi!
thanks!
hi!
thanks!
Hi Pilo,
the problem with this programmer is, that it uses the low-voltage programming mode and therefore allocates pin RB5, which - once the mode has been enabled - cannot be used for any other purpose anymore. Consequentialy you cannot drive a LCD module, which requires RB5 as data pin.
Hi Pilo,
hum… But, I put the pic on the programmer, then put it in the midibox… Because I use RB5 in the programmaing sequence then i can’t use it anymore??? Maybe I should download the PIC18F datasheet…
I want to make a stand-alone programmer (not in the midibox)… ???
Because I use RB5 in the programmaing sequence then i can’t use it anymore??!!??
yes!
From the PIC18F452 datasheet
The High Voltage Programming mode is always available, regardless of the state of the LVP bit, by applying VIHH to the MCLR# pin
While in low voltage ICSP mode, the RB5 pin can no longer be used as a general purpose I/O pin.
yes!
