PIC ID issues using MPLAB IDE
  I burned the bootstrap program onto my PIC in MPLAB. I did not know where to set the ID information in MPLAB IDE. So, I assumed that the .hex I downloaded from ucapps would be 0x00 for a standard character display.
  However – The device ID is, in fact, 0x70 (I saw that on MIDI OX and MIDI monitor (mac)).
  When I loaded MIOS for ID 0x70 everything works – I even get random MIDI data when I load the midibox64 program.
   My LCD does not work, though. I checked all connections and they are fine. How do I verify that the LCD was set up correctly in the PIC, or do I need to remove my PIC and reburn the bootstrap program? If I do so, how do I set the correct ID in MPLAB?
  Would you reccomend compiling the assembler files instead of using the compiled .hex versions?
   By the way, I am using a standard character display (hitachi type, 2X24)
Thanks
Sorry to ask a question that gets asked so many times (how do I make it work?)… However, I couldn’t find any info on burning the PIC with MPLAB searching the forum.
perhaps this page might help http://www.ucapps.de/mios_bootstrap.html
it lists the place in the hex file to edit the device id
See this article
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1053942064;start=11#11
Thanks so much,
  I assembled your work-around code in MPLAB and burned it with the correct ID. The PIC then loaded MIOS. The LCD works. I then loaded a small program and it did A to D quite well.
Thanks,
Lorin
