Hi guys,
Question: While looking at the PIC Burner schematic http://www.ucapps.de/mbhp/mbhp_burner.pdf. What is the pin number of DATA_Out, DATA_In, CLOCK, Vdd_En, Vps_En, & Ground on the DB25?
thanks in advance..
Hi guys,
thanks in advance..
Hi docbrown,
Data_out (Acknowledge) is pin 10. Data_in is pin 2. Vdd_enable is pin 4. Vpp_enable is pin 5, and clock is pin 3. Signal ground are from pins 18 to 25. Attached is a pinout of the D25. Hope this will help.
Regards
Shum
Hi docbrown,
Regards
Shum
Shum,
I will re-wire this burner again. No wonder the red light is always on >:( Looking at the connector in the diagram, it seems like its facing back which is the conductor side, but not the pin side.
thanks… ;D ;D
Shum,
Just to give you an update. After I switch around the connection, it finnaly works!!
Yay!! I loaded the bootstrap on the PIC… ;D ;D ;D ;D
thanks again..
Hi docbrown,
Glad to be of service. Your are welcome.
Good luck with your midibox project.
Shum
