Peripheral! 16x4 BLM addon
This is based on Ilmenator’s 16x4 BLM PCB that he was kind enough to let me liberate from him and a matte Ponoko laser cut case.  I used the same LEDs I used for my SEQ and they match perfectly brightness wise.  I interfaced it to the CS via a mini din8 connector which needed to be buffered to work properly (thanks to TK).  I’ll post the files for the case and the brd and schem of the buffer I used (I obviously just did it by hand here).
Thanks to Ulrich and Throsten for another great project!
These are the files for the case, please note that there is NO HOLE for the connection, the location and size of that will depend on how you want to implement this so its up to you.  Standoffs were 8mm for the top, 18mm for the bottom.  I ended up grinding the 18mm ones for a tighter fit so 16mm plus washers may be a better choice to make up for tolerances
http://misw.us/p2_blm_case.svg
Here are the sch and brd for the buffer. I designed it to simply attach to the board via female DIL on the back like I have it on my PCB.  I have NOT actually made these yet so you probably want to check it for any errors but it is simply based on the connections shown the LPC17 schematic and is how I wired my hand made board.  Also worth mentioning is the DIN8 socket and DIN cable I used despite having the same colored wires, did not have those wires connected to the same pins so make sure you check with a meter..
Nice job. I’ll definitely watch for your files. This is probably the next addition to my seq4.
very nice :]
Fantastic job - and thanks for your kind words! Best, ilmenator
Well done, looking really great! :slight_smile:
files added..
Cool project. I want this too.
BTW, Where did you get those green on black displays?
those are the Kyocera ones (formerly Optrex)
Got any order number or supplier ? I assume you didn’t made a PCB … breadboarded ?
Mouser: http://www.mouser.com/ProductDetail/Optrex/C-51850NFQJ-LG-ACN/?qs=sGAEpiMZZMt7dcPGmvnkBvYnOvX7dbDNGFPEbefb4Dw%3d
Yeah, I just bread boarded it.  Didnt feel like waiting 2 weeks and it took maybe half an hour
