peculiar problem
hello there
i have a most peculiar problem that really has me confused, i completed my all in one midi-box and after the usual trouble shooting etc all seemed to be fine. The other day i even got it interacting the way i wanted with reason and abelton,after being in heaven and playing with it for about 4-5hrs it started producing random midi signals
so i thought it was something to do with ain interconnections again, after in inspecting the wiring i couldnt see anything wrong. so i thought to re-install the midi-box app this i did with mios studio2 when using this after installation there where no random midi signals (problem solved i thought)but when i go back into midi-ox at first there are no random signals but as soo as you touch a pot this signal just repeats continually (which ever pot you touch is the one that repeats continually)this is just in midi-ox and not mios studio it also works fine in reason and abelton obviously i could just use it as is but its a bit worrying any ideas to what is is would be gratefully received
regards kris
ps i tried reinstalling midi-ox
If this is just happening in midi-ox then I suggest that midi-ox is echoing received midi data back. One way to test this is when it happens, disconnect the MIDI Out from midi-ox.
It has been a while since I last used midi-ox so this may be complete rubbish :slight_smile:
Cheers
Phil
thanks for the reply thats stopped it okay does that mean its just aproblem with midi ox, as ive never had this problem before
regards kris
Are you sure that you haven’t enabled an “echo” feature on midi-ox, I can’t run it at the moment to check…
If you don’t get the problem with any other program I wouldn’t worry about it :slight_smile:
Cheers
Phil
thanks for that
regards kris
