Hi
I have searched hi and low for this. I am sure i have seen it somewhere around here month ago.
Somewhere there must be PDFs of all the PCB modules available for download, so that i wont have to use eagle or anything.
I have tried going from the eagle .brd file to pdf myself, but it keeps looking strange.
I have been explained in details how to use eagle, but apparently i must pretty thick :-\
Can anyone point me to printable PDFs (or other format) just right for printing?
Carsten
afaik there are only PDFs available of the curcuit schematics but not of the PCB layout. Maybe someone could make a screenshot from a PCB layout in eagle and convert the image into a PDF document.
That would be so nice. I hope so…
Carsten
Thanks. I just saw the burner today. Cool, im ready to go
[EDIT]: you might wanna fix the link for the burner, it points to the sid, but i just copied the text-link.
say… if you had the other PCBs for the midibox sid laying around. I wouldnt mind you posting them :
I know i said i wanted to learn eagle, but its just so much easier to ask.
Carsten
Once again Thanks.
I was thinking, since in time i am planning to build both the the sequencer and the FM synth too, i might as well make the PCBs needed for them when i am allready going to make the once for the SID.
So if any one has the following PCBs as PDF, they would be much appreciated:
MBHP_OPL3
mbseq_din_v2
mbseq_dout_v2
mbseq_din_vintage
mbseq_dout_vintage
I havent really been checking out the seq and fm projects,and im sure it will take me a long time to create the SID. But i believe the above mentioned PCB are the only once needed for those projects apart from what i allready have links to in this post.
/Carsten
PS: if anyone would like to talk me out of creating the PCBs for the other projects at this moment in time, please tell me so. Personally i cant really see why i shouldnt just create them now, while allready working with PCBs, and put them away for some time - but there might be some reason that i dont know of. Thanks.
@Altitude: Thanks man, never know when those might come in useful. Have you linked to them from the wiki as well?
Here i am again ;D
Altitude, do you think you have the pdf of the midi in/out led :-X
