PCB question for modular SID V2 build.
I had a small panel fabbed for the CORE,  SID and DIN/OUT modules with the available layouts in the wiki.
The fab house printed these as two layer boards but the drill outs show the vias for the bridges.
Stupid question,  the soldering guide instructs to solder the bridges.. but do these still need to be populated if it’s already a 2 layer board?
To me, the available files show copper on both layers. Check with a multimeter?
I’m just looking for continuity between the bridge points?
Yep, also you’ll see the track drawn on the copper layer as well as the plated via.
I can’t read layouts so I had no clue if there was a second layer or not.  So I was confused when I saw the drill holes when the boards came.
Thanks Latigid!
Edit: I guess I should have known also from the traces underneath the board lol
Learning is a slow process for me
